Are there any Peplink Multi Cellular Routers (with built-in SIM) that work in Thailand?
I have a MOTG4 with Sierra Wireless USB modems that works well, but I need to boost the 4G LTE signal and want to find a router to which I can attach 4G LTE aerials.
Any of our MAX (European version) should work in Thailand.
If you are looking for Quad LTE simultaneously, HD4-LTE-E would be the answer. Or if Dual LTE is needed, that would be HD2-LTE-E. Otherwise if just Single LTE is fine, then you could go for MAX BR1-E.
