This may be a stupid question. When looking on InControl2, I’m trying to determine the Mbps network speed, as you would running a speed test on your phone. How and where is this determined?
Thanks!
Thanks!
I would view that via this method.
Incontrol → Org → Group → device (Device Level) → Reports Bandwidth and Usage Reports → Bandwidth Per-Minute or realtime.
I frequently perform this task. If you have an active SpeedFusion connection, you can navigate to Status/SpeedFusion, click the right-arrow, and at the bottom, conduct a download and upload speed test over that connection. It will measure the speed over the tunnel, which is close to what you want.
I wish you could run plain 'ol speedtest.net from it!
