Cellular modem reboot loop after cellular firmware update interruption
I’m looking for guidance on recovering a MAX BR1 5G where the router itself is still reachable, but the cellular modem appears to be stuck in a reboot loop.
We were having cellular coverage/connectivity issues and attempted to perform a cellular modem firmware update. During the firmware update process, the unit experienced an unexpected power interruption.
Since then, the router web interface remains accessible, but the cellular modem repeatedly initializes/resets and never comes online. When I attempt to check for cellular firmware updates again, the UI returns:
“Please try again later.”
Event logs look like this:
May 12 06:18:45 WAN: Cellular SIM A cannot connect, switching to SIM B
May 12 06:12:29 WAN: Cellular SIM B cannot connect, switching to SIM A
May 12 06:06:28 WAN: Cellular SIM A cannot connect, switching to SIM B
May 12 06:00:34 WAN: Cellular SIM B cannot connect, switching to SIM A
May 12 05:54:29 WAN: Cellular SIM A cannot connect, switching to SIM B
May 12 05:48:20 WAN: Cellular SIM B cannot connect, switching to SIM A
May 12 05:42:06 WAN: Cellular SIM A cannot connect, switching to SIM B
May 12 05:35:56 WAN: Cellular SIM B cannot connect, switching to SIM A
May 12 05:30:04 WAN: Cellular SIM A cannot connect, switching to SIM B
May 12 05:24:08 WAN: Cellular SIM B cannot connect, switching to SIM A
I even tried loading a new eSIM from a carrier we’ve never used before just to see if that made a difference which it did not.
Is there a known recovery process for a cellular modem that is reboot looping after an interrupted cellular firmware update?
I have a ticket open #26050311 for this but I was hoping maybe had something while I go through the usual 20 questions process of a support ticket over the span of several business days.
A ticket is the path forward. The recovery process is a Peplink support only capability.
If your ticket contains the same information you put here, it should be routed to the correct team and actioned relatively quickly. I would make sure that Remote Assistance is enabled and the device is connected to a wireline internet source while being left online. In this case, if you selected the option in the ticket to allow peplink support to make changes, this would happen pretty quickly. I would also say something to the effect of “the device is hardwired to internet, please recover the modem as soon as possible.”
Ok, thank you. It’s been about 24 hours since I’ve gotten a reply on the ticket. I’ll update it with that info.
Thanks again
