Very new to Pepwave and impressed so far. Coming from another product I used in my RV/Motorhome I installed the MAX BR1 MK2 last week and am still learning the configuration. I have two SIM cards in the system; Verizon and AT&T. Cellular is priority 1 followed by WAN and the two WiFi networks. WAN is another WiFi system plugged into the WAN port (former system I used in the RV) but most likely will remain offline.
My question is regarding Cellular. Take for example SIM A (Verizon) is connected. If the network slows down or disconnects I want it to failover to SIM B (AT&T) nad vice-versa. I don’t see any speed test configuration such as slowest desirable speed below which a failover will occur. So far in my one week of usage I’ve seen the device disconnect and reconnect and remain on Verizon which may have had poor connectivity at times. I have never seen the system switch over to AT&T (SIM B).
How can I configure this so the system will automatically switch between the two Cellular sources?
It would be much more ideal, I believe, if the Network Configuration / WAN area divided each SIM slot into its own for prioritizing for failover. I’m not sure why they are both pooled as one or how to really configure this per my desires.
Thank you for your advice in configuring two cellular sources for optimal use, speed, and uptime.
