I’m trying to get the captive portal on our MAX HD4 LTE working. What do I need to do to trigger it? I have it enabled and using the built-in splash screen but I can’t seem to actually have it come up, it just goes and says it can’t find the home page (which is fine because I don’t have any SIM cards plugged in; doing testing well indoors). I’ve removed the MAC of the test/admin machine from the DHCP reserved list so it doesn’t think it’s a manager and can bypass the splash screen. I just can’t work out where a user would connect to the router and make the splash screen show up.
Also, does the hostname matter for anything? Do I -need- a live Internet connection to have the splash screen come up, does it go home to captive-portal.peplink.com for anything?
I kind of feel like I’m missing something obvious here.
Thanks!
