Captive Portal Quote Reset By Calenda Month
Dear Peplink,
Could we change the reset quota based on the calendar month instead of days?
The reset quota is under Captive Portal → Guest Account
For example: 1st day of every month.
Similar to the Bandwidth Allowance Monitor in the Cellular setting.
Reference support ticket #24080229
Thanks!
Regards,
Hong Yee
We will implement your suggestion in the next major release. Thanks for your suggestion.
Hi Michael,
Thanks for the reply.
May I know if you have any scheduled date for the next release?
Is this related to the firmware or the InControl cloud system?
Thanks!
This feature will be included in 2.13.3 which shall be released by the end of this month.
Thanks!!!
I would like your assistance in the following features:
1-User-Specific Speed Limitations:
individual speed limits for each user on the network
2- QoS Management:
If possible, I would like to manage the Quality of Service (QoS) directly from InControl to prioritize traffic and allocate bandwidth effectively
3-Carry-Over Feature
carry-over feature, allowing any unused quota from a user or token to be rolled over to the next Qouta day
