Dear Guys,
Could you advise how to control captive portal on Peplink balance using IC2 ? I can only see hotspotsystem on the external server type !
Dear Guys,
Hi Hootan,
We just released InControl 2.3 to “mars” which should be the system your organization resides on. So you could now manage your Balance’s VLAN networks and captive portal on IC2. So first you create a captive portal. Second you create a VLAN network with the captive portal applied. Then the VLAN and the captive portal will be applied into your Balance. Any clients on the VLAN will see the captive portal.
Great.
