Hello!
I am currently having an issue with the “captive portal”. I have set it up in the “Peplink’s 580 Admin”, created accounts etc. When I connect to my guest network, I will be redirected to the captive portal - I can see my custom logo etc. (url: https://captive-portal.peplink.com/login) - that works so far.
But whenever I try to login, it tries to open/redirect to “https://device.pepwave.com:8000/cgi-bin/portal.cgi”, which will not happen - IE says “Internet Explorer cannot display the webpage”.
When I do a “ipconfig /all” on that client, I can see, that the “Peplink 580” is set as default gateway and DNS server… I have not setup anything in “InControl” as I understand, that this part will be handled by the “Peplink 580” itself.
Although, if I go into the APOne’s web admin, I can see, that the “guest portal” seems to be “managed” by “InControl” …
Any ideas?
/bjoern
