It would be possible to setup a Captive Portal in InControl2 without using Peplink WiFi, We aim to allow a portal with VLAN from Peplink to redirect the guest client to the internet.
Best regards
Best regards
@mhbirri ,
Yes. This is supported.
For router device, the Captive Portal settings is enabled at the VLAN settings. Any device connect to the VLAN will prompt for the captive portal access.
