Captive Portal Guest Account management
Hi All,
I currently have a system set up with a Captive Portal configuration. The Captive Portal is configured for Guest Accounts, each with a daily data usage quota.
For example, Guest Account A has a 1GB daily quota, and once the 1GB is used up, can the user switch to Guest Account B, which also has a 1GB daily quota?
Current guests required to sign in mode is once only.
Thanks.
When the quota expires they’ll see the splash screen, or would have to go back to it and log out, then log in with the other account
Hi, Thanks for the reply!
