Captive Portal - Dual WAN
We are currently using BONE products.
Is it possible to use the captive portal for each WAN after configuring as below?
For example,
Campany Name : HD2500
WAN1 - STARLINK1
WAN2 - STARLINK2
Captive Portal
ID : user1 , PW : 1312313 → WAN1
ID : user2 , PW : 1412321 → WAN2
Do you have any products available?
Thats not likely, there are so many bugs in captive portal and a log out page already waiting for 5 years. I dont think Peplink will have time to think add some new function on captive portal.
Thank you for the good information.
Is there any other equipment that can function that way?
If you have experience, please recommend equipment.
