So I was trying to setup a guest SSID with Facebook Captive. But it enabled it for my entire LAN.
Just wanted to confirm if I disable it for LAN it means that single SSID won’t work either?
Hi Michael,
Understand that you have created the same forum post regarding to Captive Portal (Facebook Social).
You may refer here:
Do consider isolate “SSID with Facebook Captive portal” using different VLAN and this should solve the LAN captive portal issue.
Thank You
