ALl,
We are using Peplink Captive Portal.
The current setting is
- Guest Account
- Guest required to login every time they connect.
- That is the only way to show the usage quota.
There are a few things which we are experiencing.
- The connection stopped suddenly. The only way is to disconnect from WiFi and reconnect. Login again to get access again.
- Is there another way to access to the usage quota?
- Is there a setting to allow certain web which will not use up the quota?
Thanks.
