Hi - I just installed an AP One AX. It is managed via my Balance One 600Mbps Dual-WAN Router with wifi. When I go directly to the APs login page via its IP address or via the link in the Balance One’s Managed AP page and try to login via the defaults - user: admin password: public I get “Invalid Username or Password”. I have reset the AP and rebooted. Although admin:public is noted on the AP itself as the defaults, I tried root:admin, admin:admin and the login I use for the Balance One - same result.
AP is on firmware 3.9.0 build 4921.
Balance using 8.1.1s118 build 5100
I have Group-wide SSID Settings in INControl turned off. I did add the AP serial number to devices in InControl. I am always confused on what to manage via InControl or locally via the Balance One. Don’t think it should matter with respect to not being able to directly access the AP but could be wrong?
Any help appreciated
