Hi, I’ve talked to 3 different people at ATT about needing to login to an account to manage it. To set it up ATT has to text me numbers to get past there security. I never get their texts. So when I go to my router settings and follow what the PepWave forum says to set it to I still get nothing.
I have a prepaid plan because I will only use this router a couple of months a year, for now.
I copied this pic from the internet to show the area I’m talking about. They have Verizon/T-Mobile I would think mine option should say ATT but it says cell.
It can take longer than you’d imagine to go and get the sms from the SIM. Try loading the page wait 5 mins then refresh.
Thanks, but this was over the course of a couple of days and there’s still no texts.
I asked ATT if I could use my cell phone to do a test text, they said it wouldn’t work, so I tried it and it didn’t.
I’ll probably switch carriers in a month or two and see if the others do a better job, I liked ATT’s plan.
