I forgot to eneter a vehicle ID in Pepewave Web Admin and I cannot get back in to edit. I have tried 192.168.50.1 and admin/admin doesn’t work i tried 192.168.88.1 nothing any ideas ?
Can you get in via InControl2?
If the device is online, this is the easy way.
If the device is cellular and offline, you could plug a network cable into the WAN port and assuming you haven’t disabled or customised the WAN ethernet settings, it should bring the device online in InControl2 which would allow you to remotely access the device and then change the password.
