Running 8.3.0 on a Max Transit, with the optional OpenVPN WAN module activated. If I open teh setting page for the OpenVPN WAN connection, there is an Enable check box that is ticked. If I clear it to disable the connection, then click Save and Apply, it appears to accept the new settings, but the OpenVPN WAN connection continues to try to connect. And when I reopen the settings dialog, the Enable box is still checked even though I unchecked it previously. Other settings seem to be retained properly on a Save-Apply.
I am having the same problem on my Balance 20x FW 8.4.0 Build 5416. How to disable OpenVPN and remove it from the Dashboard. Any advice?
Fixed problem by unchecking “Use as backup wan” in the OpenVPN settings.
