Dear Support,
I cant access web admin via WAN connection after enable IP PASS THROUGH of cellular, May i know any workaround or solution.
Dear Support,
If this is the BR1. I would register the device in our InControl2 site and then upgrade the BR1 to our new 6.1.2 beta firmware which actually allows you from IC2 to remote directly into the BR1 interface from a clickable GUI button “Pepmin”. You can connect even if it is a private IP address on the WAN.
