Hi all,
I am new Captain of a yacht. We have a PEPLINK product on board. I don’t have login and password.
So I reset the product
Connect to the product by the borwser on 192.168.XX.XX
But still appears login page and nothing in the manual
Thank you for your support
Which product is it? The default login is either http://192.168.50.1 or http://192.168.1.1 but if the device is managed by InControl2 by whoever set it up, then even after a factory reset if it has an active internet connection it might be automatically changing the wed admin management IP / port and username / password.
So pull the device from the rack, pop out all the SIMs (if it has them) unplug the WAN cables and then factory reset by holding in the reset button for a 20 sec count.
Then you should be able to login using the default username / password.
