Cannot remove Setup Wizard from Peplink Balance 310X on 8.3.0 build 5584
This is a very low priority but nonetheless something that doesn’t work. When using the “You may click here to hide the Setup Wizard menu and unhide it in the Status Page.” option it goes through the process of saying there are changes to apply but once applied the Setup Wizard tab remains on the Dashboard under General. I searched for information or reports about this but found nothing so I’m reporting it.
