I have downloaded InControl2 for linux. Total file size is around 9GB. After extracting the tar file and import in vmware esxi, file type show .0-20170622 and cannot understand in vmware. I follow the instruction in installation manual, but it not work.
Do you have error screenshot to share here ?
The file type after extracted seem like invalid. Can you please try other unpacking tools (7-zip) to extract the file ?
You should have the followings after extracted the files:
I download again the files and now start VMs, screen show like that. And also DB cannot login. Can I know DB username and password?
- Please check if each VM has 2 disks : provided systemdisk + self created datadisk
- Check the Network Connections: DB => NIC1=Internal || InControl => NIC1=WAN NIC2=Internal
Contact [email protected] for further questions about ICVA.
I just finish creating of VMs, but I cannot login Incontrol system control panel. I also cannot login to CLI, what is the username and password? I cannot check the IP address of Incontrol VM, so I cannot go to system control panel.
Regard,
YPH
The InControl VM needs to receive a ip address from DHCP. When clicking a few times ‘Enter’, the assigned ip address should be visible.
