My MAX BR1 Pro 5G is usually connected to a WiFi connection with Cellular as a back up.
After a day or 2, the WiFi conenction fails and the router swaps to cellular.
Every time I have noticed thiis, when I login to the router in says ‘No WiFi avaialble’ but if I check ,on my phone, WiFi conenctions are available.
I then reboot the router, it finds the WiFi and connects OK
Any idea what could be going wrong?
Is there a way to get an alert if the WiFi conenction fails?
TIA
