I can’t log in using the router ip address, I can access the router via incontrol.
when I try to connect to remote web admin in incontrol I get: Access Error: Connection reset
Attached is a screenshot of the attempt via the IP address
either the web interface is not running on port 443 on that IP or you are access from a network that is not allowed to get access to it. Does remote web admin work from InControl?
