I had a Surf Soho purchased in 2012, hdw 2, but it kept dropping internet. I purchased this one when I moved from Verizon to Sprint, kept assuming it was Sprint (Much better speed, and cheaper), but recently put my old Cradlepoint MBR95 back in use, NO DROPOUTS. I then thought it was the Peplink router, so just purchased a NEW Surf Soho MK3, just hooked it up this morning, and it will not connect to internet at all! It sees the 341U modem just fine, but refuses to connect to internet. I put my old Cradlepoint back, and it works perfectly. I want the Surf Soho because of the much better WiFi signal, as it will reach anywhere in my home, but the Cradlepoint is very weak to unuseable in areas.
Is there a known problem with the Surf Soho and the Netgear 341U that can be fixed! Getting a little desperate, having purchased TWO Surf Soho units now, and still cannot get reliable internet, where the old Cradlepoint is extremely reliable but weak WiFi.
