I have a Peplink MAX BR1 Mini 5G. It has the latest firmware 8.5.1.
Through months of investigating, I have determined that in our area, T Mobile throttles the connections of all available bands except 71 to text only speeds between midnight and 6:30am. My other T Mobile home internet gateway currently uses band 71 and works at normal speeds all the time. I would like to be able to use band 71 on my Pepwave after midnight to avoid this. I try to force use of all of the bands n71 and 71 but my Pepwave will never connect (display just shows “connecting”).
The signal is very strong -65 RSSI.
Any ideas as to why i cannot connect?
How old is your SIM? n71 is now SA but on older SIMs it might be NSA and need b2 or b66 as an LTE anchor band.
Did you update modem firmware to latest?
I have few 5g mini, will check it today.
Hi Andrew,
Thanks for the quick response. I have had the sim for a few years now. However it is provided by 3rd party so i dont know how old it really is.
Your comment about anchor bands prompted me to try some tests during the day (normal operation) which make this issue even more confusing:
- Selected bands b66 and b2 - Pepwave connected b66 Primary, b2 SSC1. Normal upload/download speeds
- Selected bands b66 and b71 - Pepwave connected b66 Primary, b71 SSC1. Text speed ul/dl speeds
- Selected b2 only - Pepwave would not connect
- Selected b66 only - Pepwave would not connect
- Selected b71 only - Pepwave would not connect
Looks like 2 bands are required for a connection but im not sure why im getting text only speeds with 66/2 after midnight and 66/71 all the time
Hi Andy,
I do have the latest firmware loaded but i am curious as to whether you are seeing simular issues.
