Can sim injector connect to dome pro using speedfusion
Hi , I have a client that wants to use his dome and his sim injector from different physical places (countrys), can I connect the sim to his dome using speedfusion?
Hi Evgeniy,
there are two options how you can do it. One is describe in the manual, please check Scenario 4.
The another one is FusionSIM which is currently in the Beta phase. You can contact your reseller or VAD to get more details about it. FusionSIM allows auto SIM selection based on various criteria + other advanced features.
