This is for a Balance 20 running firmware
I see several instances of service “BitTorrent” in the list of Active Sessions list. Can I block or de-prioritize this using QOS?
Hello Dan,
Unfortunately, you are not able to block or de-prioritize BitTorrent with Balance 20
Instant Messengers / P2P File Transfter Blocking feature is available with the model Peplink Balance 580 & above at the moment.
Best Regards,
Haruki
The Peplink Team
Why can’t we block/limit bittorrent with Peplink 380 ?
I have a 380 and a 580, but I don’t see how to block/limit Torrents.
Hello, will IM & P2P File Transfer Blocking be available on 380? what’s the updates on this please?
How about the Peplink MediaFast 500 B and MAX HD2 LTE with Mediafast? Will they have this feature?
IM & P2P File Transfer Blocking is an experimental feature. It is only available on Balance 580 and above.
This feature is not supported in MediaFast 500 B and MAX HD2 LTE with Mediafast.
