Can I use Pepwave Max Br-1 as a SMS gateway?
I checked through the Pepwave Max BR-1 setting page and can only find the SIM toolkit that allow read sms but cannot find any to send sms.
We don’t support this at the moment. This should be a new feature. Can you share the used case?
No Can Pepwave Max Br-1 do not support SMS gateway service
An sms gate way helps you to send and receive sms from computer. This api will work on sending sms for a list of people.
I would use this to interact with prepaid cards. Some ISPs don’t use only USSD codes for communication / service.
