I tried to SSH into a Surf SOHO firmware 7.0.1 for the first time and the router did not take my admin password. The password had special characters in it, so I changed it to just numbers and letters. Still can not get in.
Using Putty v0.70 from a Windows machine. Connect to router, enter admin userid and admin password, then get error “server unexpectedly closed the network connection”. SSH is from the LAN side on a non-standard port, if that matters.
User Manual has no additional information about SSH access, just how to enable it.
Putty SSH log file is below, nothing useful, at least to me
~=~=~=~=~=~=~=~=~= PuTTY log 2017.10.07 19:11:17 =~=~=~=~=~=~=
login as: michael
[email protected]’s password:
UPDATE: same problem logging in with SSH to a second Surf SOHO. This time, firmware 7.0.2 and using WAN side rather than LAN side. First router was HW2, second MK3.
