With Firmware 7 on a Pepwave MAX BR1 LTE or BR1 Pro LTE, can I use the LTE cellular port and the physical WAN port simultaneously as two separate gateways to the LAN?
Thanks for the help.
You can refer to firmware version 7 release note for the info.
Reference 15783 [Load Balancing and WAN Smoothing] Additional, selected MAX single cellular models now support load balancing and WAN Smoothing.
Devices Supported
MAX: BR1, BR1 Slim, BR1 ENT, Transit
