The Surf SOHO is cheaper than that (the Peplink Device Connector). Any reason not to use that to push Wifi-as-WAN to a Balance router IF I end up upgrading to one?
As you say, β[n]ot ideal but budget is limited.β That would certainly not be my preferred approach. However, you will find several threads here in which using a SOHO as an AP are discussed. Before I did that Iβd likely use a product similar to the first link I provided. But, as they say, βYMMV.β
The Optimum hotspot is using 5GHz, therefore I am considering a TP-Link CPE510. Another option is a NanostationM 5 GHz Loco because it looks like many people are talking about this. Both of them said they have 13 dBi gain but TP-Link is cheaper since it includes a PoE adaptor.
Optimum uses a mix of 2.4 and 5ghz on their outdoor/commercial access points (Cablewifi SSID will be present). Optimum off of modems in homes might now be all 5ghz but I dont remember.
I have the balance 20x, how do I enable a second internet connection through ethernet?
Hi. Actually, this has been discussed a number of times here on the Forum. Do this:
- Navigate to Network β WAN
- Under Connection Name select the USB item
- Click the blue β?β in the upper right corner of the pane that pops up (as shown below.)
- Click on βhereβ in the little box that pops up.
- Configure your new WAN.
(This example is from a Balance 210 β your screen will look similar.)
