Can I use API to configured Cellular settings and Health Checks
We have hundreds of Peplink MAX BR1’s deployed all over. We need to update the Cellular Settings and Health Checks on these devices. I don’t see a way to do so from the IC2 dashboard. I am also not sure if there are available API Post or Put commands either.
Do I have any options to make these updates at scale? Our operation is expanding too, and so we really need a way to remotely configure these in the field.
Thanks!
Hi Luis,
Have you seen this API document for firmware 8.4.1?
There are some options for health checks.
Not sure about what cellular settings you would like to change but there are some options for APN etc.
Hope this helps.
Thanks Joey-janssen,
This detailed breakdown of the API calls was very helpful. I think I see some of the resources in the “POST /api/config.wan.connection” section that are what we’re striving for.
