Can I connect AP One AX WiFi directly to Starlink Mini
Hi Guys,
Sorry for the silly questions, but I am wondering if I can simply plug the AP One AX WiFi directly to the LAN port on the Starlink Mini router. The purpose would be to broadcast WiFi from within the van rather than using the mini built in WiFi sitting on the roof of the van. To be fair, the built in WiFi seems to broadcast pretty well through the metal roof.
My intended plan was to use the Max BR1 Pro 5G router and AP One AX together with the Starlink as WAN, but still working through slow speeds with Peplink router in this configuration (looking at a L2 switch as recommended).
Thanks!
Yes. The Ethernet on the Starlink Mini will provide a DHCP address to the access point, and to any devices that connect to the access point over WiFi.
