I am trying to get a BYO eSIM activated on a B-ONE-5G. I am not using InControl as it is overkill for my one router setup. The local web interface only shows Peplink eSIM. Is it possible to configure a BYO eSIM through the local web admin interface?
You do get 1 year of IC2 for free, so why not use that to do the BYOD eSIM activation ?
Hi, Iām running into a similar problem. I used the IC2 free plan to activate the BYO eSIM at first, but now I need to reconfigure it to use another provider, and my IC2 plan has already expired (buying it would be overkill for our configuration). Is it possible to make it through the WebAdmin?
IC2 is required to provision eSIM, per Peplink.
