Seems to be a bug matching an Outgoing Policy?
My IP 192.168.6.100 is not being routed to my Rule to Speedfusion VPN?
The Hint is apparently Filtering by SSID?
Why is the source and destination the same?
I tried with both Source & Destination and Source only does not route to VPN.
Source os LAN not Wi|Fi dont get the bit about SSID?
What model of peplink?
What firmware version?
is the subnet 192.168.6.0/24 network native to the peplink?
Do you have other rules that would match the traffic above this?
With the limited information I currently have, I would only put the ip range in the source.
MAX-HD4-LTE-E, 2933-D24B-1420, 8.4.0 build 5595
Native subnet Pepwave is 172.16.3.1/24, currently one Cellular 2 (French) with Speedfusion for UK IP.
Thanks for your assistance,
Rookie mistake IP is NAT’d to Pepwave, does appear to do OK now but still do not understand the Help balloon regarding SSID?
