I was playing with the logging feature of the Windows 10 firewall and found that it logged some traffic that I did not expect to see at all.
The Win10 machine is ethernet connected to the router on the untagged LAN. Its subnet is 192.168.1.x. The router also has a WiFi network that is assigned to a VLAN that does not allow inter-vlan routing. This wifi network is using the 10.44.44.x subnet and WPA2 Enterprise.
There is an iPad connected to the Wifi network with IP address of 10.44.44.105.
The router is assigned 10.44.44.4 in this subnet.
The Windows 10 firewall, logged this activity
#Fields: date time action protocol src-ip dst-ip src-port dst-port size tcpflags tcpsyn tcpack tcpwin icmptype icmpcode info path
It seems as if packets escaped from the VLAN and were visible to the 192.168.1.x untagged LAN.
Granted these are special IP addresses and I don’t know what they are used for, but should anything break out of a VLAN?
Layer 2 isolation was NOT on for the VLAN at the time. I have since enabled it. I had overlooked it because the advanced VLAN settings are not visible by default.
Update: It seems that WPA2 Enterprise is critical to this.
The iPad in question is now connected to a WPA2-PSK SSID and there is no packet leak. The RADIUS server used by the WPA2-Enterprise network is a NAS on the untagged LAN that shuts down at night, so the iPad must have fallen back to the WPA2-PSK network which it has used before. Each SSID used by the iPad is assigned to the same VLAN.
Do you mean when the IPAD connect to WPA2-PSK SSID have no issue ? and you only see the firewall logs when IPAD connect to WPA2-Enterprise network ?
The firewall logs as given above is more on Multicast traffics … just worry the IPAD connect to the wrong VLAN with IP address 10.44.44.105 and generated such logs.
It turns there are two issues.The log entries below are from a Windows 10 machine. What Apple uses port 5353 for is not relevant. Whether the UDP packets were allowed or dropped is not the point. The point, to me, is why the Windows 10 machine sees these packets at all since the VLAN does not allow inter-VLAN routing. I realize this could be a documentation issue. Many issues are.
The traffic below happens on either SSID, WPA2-PSK or WPA2-Enterprise. The router (10.44.44.4 on each Wi-Fi SSID as they are both on the same VLAN) is doing some type of broadcast from port 67 to port 68 that is being heard by the Ethernet connected Windows 10 machine on the untagged LAN which is the 192.168.1.x subnet.
The traffic below is coming from the iPad (10.44.44.105), not the router. it is only seen on the Windows 10 machine when the iPad is on the WPA2-Enterprise SSID
#Fields: date time action protocol src-ip dst-ip src-port dst-port size tcpflags tcpsyn tcpack tcpwin icmptype icmpcode info path.
Another instance of same/similar thing. No Wi-Fi at all.
LAN port 1 is a Vonage telephone adapter. The port is its own VLAN (10.66.66.x) that does not allow inter-VLAN sharing. The LAN port is the entire VLAN.
An Ethernet connected Windows 10 machine is on the untagged LAN (192.168.1.x). It is connected to a dumb switch and is running software that monitors all DNS requests. The software is DNS Query Sniffer from here
The program sees DNS requests from the Vonage telephone adapter.
Sorry about the delay responding. The SOHO has two dumb switches connected to two LAN ports, a smart switch connected to the third LAN port and a VOIP telephone adapter connected to the 4th LAN port. Each dumb switch has a few devices connected to it. All Ethernet.
