BR2 - VWAN With primecare
Hey All,
I’m configuring a BR2 today, and I noticed that the VWAN feature isn’t enabled with Primecare like my BR1 Mini has. Is this intended behavior? I see in the KB article about VWAN that only certain models are supported for the 1 vwan with active primecare, but I don’t see where it indicates which models those are. I assumed that both being MAX routers would put them in the same group.
Thanks!
Try to upgrade to the latest firmware and connect it to incontrol2 and see if it applies the primecare license?
Hey Jonathan,
The device is enrolled in incontrol and running FW 8.5.1 build 5203
@sitloongs Does the br2 pro 5g include vwan with primecare, like the other models?
It’s super helpful to have a single connection to a device for both wan/lan.
Allow me to verify this and I will update again.
@Jonathan_Pitts ,
BR2 Pro will include the free vwan with primecare.
You can check the primecare model and features here :
Tested from my test device as well.
@cdagneta ,
Can you please create a ticket for support to verify ?
Ticket submitted, thanks all!
