BR2 Pro: WAN 2 connection shows as WAN 1 in the router GUI
I have a BR2 Pro running 8.6.1. When I plug in a cable to the WAN 2 Port, the web GUI shows the connection is active in WAN 1, but there is no cable in the WAN 1 port. When I plug the cable into WAN 1, it says no cable detected, on either WAN. The port activity lights are both orange indicating a connection on WAN 1 and 2. I’ve factory reset multiple times, no avail. InControl2 is disabled. Anyone experience anything like this before?
@AJ2115,
Could you please create a support ticket for the Support team to investigate and verify this issue?
Based on the symptoms, this appears to be related to an interface detection issue during device startup. It could potentially be a hardware issue, or something may be preventing the interface from being properly initialized or loaded during the boot process.
The Support team can review the diagnostic reports and system logs to help identify the root cause.
