Any advice for SIM card options for Canada?
Currently have Telus WiFi (MyFI) box… will take SIM from this device and put in Peplink BR2 Pro.
Also not sure what size SIM card slots on Max BR2 Pro (?standard, micro, nano).
I don’t have the unit yet… so can’t check… I know there are 2 SIM slots on the back though.
Also any experience with eSims with this unit (would be for USA travel).
Specifically, eSim purchased through:
Also have Starlink (standard dish… not permanently mounted/no inmotion use). Will upgrade at some point to high performance dish (in motion capable)… as soon as the standard “dishy” breaks/gets stolen/falls off flag pole ![]()
