BR2 Micro - Micro Router, Mighty Connectivity
BR2 Micro
Bring fast, reliable connectivity to places where no others can fit with this tiny dual-cellular router.
Enjoy its capabilities with instant configurability and zero-touch provisioning.
It’s micro. It’s powerful.
Discover the BR2 Micro.
Learn more
Interesting to note it’s CAT4 rather than CAT6 like the SFE was. What’s the reasoning behind that? Does it generate less heat? The SFE’s could get rather hot.
Can it be used with Starlink ? Considering the new Starlink mini can be a nice compact combination? Thanks
Hello, Acroid.
Yes… But it will not be simple task… will need a L2 managed switch between BR2-micro and Starlink and VLAN and… this device it is only two LTE CAT-4 (150mbps/50mbps)
It will be more simple to use a BR1-PRO / TST-DUO-PRO or ???.
Hello @Emily_Cheng,
Our team believes your documentation, marketing, and SKUs misprint this as a Cat4.
It should be a Cat6 or greater, replacing the previous SFE (SpeedFusion Engine) with its Cat6 chipset.
It does not make sense to roll back the capabilities of this device; please work with your team to get this misprint corrected ASAP.
Happy to Help,
Marcus :slight_smile:
Hello @mldowling, we do have a CAT-7 version (for APAC & EMEA | SKU: MAX-BR2-MICRO-LTEA-E-PRM) available via email, although it’s not listed in our current marketing materials. If you need this version, please email us at [email protected]. Thank you.
@Emily_Cheng Can you clarify what LTE category this is please? Is it CAT4 or CAT6? What modem module is in it?
