When you register a BR2 Max Pro with Incontrol2 does it disable the local logon to the router. I configured the router and set the local password and when I register the router I cannot longer login locally. If it does disable it is there a setting within Incontrol2 to enable it. Thanks,
I have resolved my issue. I realized I had a group policy set to define the local password. Thanks,
