Is there some way to update the ssl cert on the BR1 WITHOUT doing a full FW update ? The cert expired on 3/22 and is now failing on all browsers when attempting to connect.
Recommended please upgrade your device using the latest firmware (Firmware version 6.3.0 and above). This should solve the certificate expired issue.
Else you need to generate your own self-signed cert and import into the device. For more information, please refer to the attached screenshot.
Thank you
