When a multi-WAN Balance router is used with a Max BR1, it would be nice to have the Cell and Wi-Fi WAN on the BR1 running simultaneously. I would envision the priority 1 WAN then being locked to LAN 1 and the Priority 2 WAN being locked to LAN 2 in this mode. These could then go to separate WAN’s on the Balance.
I fully understand what the BR1 is in terms of fail-over. What I’m proposing is the possibility of it becoming something else if hardware and software allows.
The Surf-On-Go is not an option, sort apples and oranges since it is so much weaker in terms of Wi-Fi…
I don’t know, what is “Per Service Load distribution” and will it allow throttling the cell and Wi-Fi WAN’s independently?
Also, what is the Wi-Fi transmit power in dBm or Mw, I don’t see it anywhere in the spec?
The application is a yacht in port with “free” Wi-Fi that regularly drops out. While on Wi-Fi the captain wants to give the crew full bandwidth, but when it fails-over to cell it needs to be throttled since that isn’t free.
On another note, if you set the WAN bandwidth low on say a B580, does this actually limit the bandwidth on that WAN or does it only apply to the bandwidth control feature?
P.S. Peplink should put software emulators online so dealers can try and explore these features without the hardware. This is also a great tech support help when you may not have the exact device available to lead the customer thru the setup. IC2 is great, but of no or limited help if the device isn’t online or the link is too unstable for “Remote Web Management”.
I may miss understand the initial requirement. Please ignore the MAX Transit model as mention. As Tim mention, if you need to have more that 1 active WAN, you need to check for the multi WAN cellular router model.
Do you have further info regarding to the require setup ?
Why you need to deploy Balance router behind a BR1 device ?
Total WAN involved ? 1 x WIFI , 1 x cellular ?
How many concurrent users need to supported ?
WAN Download Bandwidth - This will not limit the actual download bandwidth for the WAN - Only apply to bandwidth control feature
WAN Upload Bandwidth - This will limit the actual upload speed for the WAN
This field refers to the maximum upload speed.
A correct value can result in effective traffic prioritization and efficient use of upstream bandwidth.
Some installations have legacy Wi-Fi bridges, other use a BR1 for just Wi-Fi or Wi-Fi/Cell. Because many frequent the Med, Caribbean and US we have installs with both a US BR1 and Euro BR1. Again, TX power is important. The BR1 is 25dBm which is 6x more powerful than the 17dBm Surf so what is the Transit? We’ve used a few Max 700 and HD2, but cable runs are long which isn’t ideal due to loss. The B580 is usually centrally located then the BR1’s are close the mast’s/antenna’s to minimize loss.
“Per Service Load Distribution” is general term/name used that referring to traffic distribution over the available Internet links base on configurable proportions. Distribution of each traffic type can be independently configured according to protocol and port number.
I’m very familiar with outbound rules and load balancing, just never saw them referred to by that name. Is it some new marketing thing like SD router instead of multi-WAN?
The general term/name for “Per Service Load Distribution” is used for sometimes ago. It’s mainly referring how the device can distribute the network traffics over the available Internet links base on configurable proportions.
Regarding to MAX Transit WIFI Transmit power, we will add the info at the product main web page. Please stay tuned and i will update you when the info is added.
So that means the Max Transit is only 79mW compared to the Max BR1 at 316mW and the Max BR1 Pro at 398mW/316mW on 2.5/5gHz? That doesn’t make the Max Transit very appealing considering it is the most expensive out of the three…
I would encourage Peplink to state the Wi-Fi TX power on all spec sheets and brochures so customers can make informed decisions. For that matter, the Max BR1 Pro spec sheet doesn’t even state it has Wi-Fi WAN unlike the Max BR1. It would be helpful if these things were consistent so maybe point that out to the marketing department: http://download.peplink.com/resources/pepwave_max_br1_pro_datasheet.pdf
BR1 and MAX Transit are different in many features and performance positioning. Hence, the pricing of the devices are not based on WiFi transmission power.
Anyway, I know where you come from. I will relay the message to the team.
