Hi all,
As the title states, any WiFi device that downloads from a hardwired LAN device is capped at around 50mbps. WiFi to LAN device is only affected when downloading, uploading seems unaffected. iPerf3 tests from WiFi to WiFi device works as expected 400ish mbps on both download and upload. LAN (Port 1) to LAN (Port 2) device also gives full throughput of 1gbps.
I discovered the issue when SMB was extremely slow on the Windows Desktop that is connected to the WiFi. The Windows Desktop on WiFi was getting an internet speed test of about 400mbps down and 50mbps up. iPerf3 was capped at about 30mbps download with about 300mbps upload.
Running a internet speed test from any device (WiFi or LAN) provides full speed (wired - 1gbps down / 50mbps up … wireless 400mbps down / 50bmps up).
Here is what my network looks like:
Here are some iperf3 tests, iPhone as the client (testing showed it does not matter what WiFi device I use).
iPhone (WiFi) to the Linux Desktop (LAN Port 1) download:
[ 5] 1.00-2.00 sec 1.24 MBytes 10.4 Mbits/sec 77 1.41 KBytes
[ 8] 1.00-2.00 sec 1.51 MBytes 12.6 Mbits/sec 72 5.66 KBytes
[ 10] 1.00-2.00 sec 1.12 MBytes 9.36 Mbits/sec 40 5.66 KBytes
[ 12] 1.00-2.00 sec 954 KBytes 7.82 Mbits/sec 59 7.07 KBytes
[ 14] 1.00-2.00 sec 1.64 MBytes 13.7 Mbits/sec 72 5.66 KBytes
[SUM] 1.00-2.00 sec 6.43 MBytes 54.0 Mbits/sec 320
iPhone (WiFi) to the Linux Desktop (LAN Port 1) upload:
[ 5] 10.00-10.01 sec 188 KBytes 105 Mbits/sec
[ 8] 10.00-10.01 sec 164 KBytes 91.8 Mbits/sec
[ 10] 10.00-10.01 sec 158 KBytes 88.7 Mbits/sec
[ 12] 10.00-10.01 sec 146 KBytes 81.5 Mbits/sec
[ 14] 10.00-10.01 sec 123 KBytes 68.9 Mbits/sec
[SUM] 10.00-10.01 sec 779 KBytes 436 Mbits/sec
iPhone (WiFi) to Macbook Pro (WiFi) download:
[ 5] 9.00-10.01 sec 7.15 MBytes 59.9 Mbits/sec
[ 7] 9.00-10.01 sec 7.21 MBytes 60.3 Mbits/sec
[ 9] 9.00-10.01 sec 7.76 MBytes 65.0 Mbits/sec
[ 11] 9.00-10.01 sec 7.46 MBytes 62.5 Mbits/sec
[ 13] 9.00-10.01 sec 6.73 MBytes 56.4 Mbits/sec
[SUM] 9.00-10.01 sec 36.3 MBytes 304 Mbits/sec
iPhone (WiFi) to Macbook Pro (WiFi) Upload:
[ 5] 9.00-10.00 sec 8.68 MBytes 72.8 Mbits/sec
[ 7] 9.00-10.00 sec 1.01 MBytes 8.44 Mbits/sec
[ 9] 9.00-10.00 sec 7.29 MBytes 61.1 Mbits/sec
[ 11] 9.00-10.00 sec 8.25 MBytes 69.2 Mbits/sec
[ 13] 9.00-10.00 sec 8.81 MBytes 73.9 Mbits/sec
[SUM] 9.00-10.00 sec 34.0 MBytes 285 Mbits/sec
Top level things I have tried:
- Replace CAT6a cable between BR1 Pro 5G and desktop.
- Reset to factory settings and test with default values.
- Move desktop to LAN port 2.
- Use Macbook Pro as server on LAN port 1 and 2 instead of WiFi to eliminate desktop being the issue.
So, the question really is, why are WiFi devices so slow when downloading from LAN port devices?
Let me know what else is needed to chase this down.
