BR1 Pro 5G Multi Cariers
I purchased the MAX BR1 Pro 5G and have a Tmobile and a Verizon Card. I was trying to set it up so if one slow or fails the other would pick up. Also, I wanted to configure to pick up the best signal. However, I only see 1 cellular connetction and I have to manually select which one to lock onto and then it reboots, etc
I am setting it up for remote work from my RV.
Thanks!
You might need a dual modem device then.
The BR1 has one modem - thus it connects to only one cellular carrier at any one point in time, and cannot test the quality of one vs. another.
You can make it fail-over to one carrier if the other is unavailable, or if one carrier is at a low signal strength:
Or you can force the issue, by specifically identifying only one SIM card to be employed (and then test, manually, which one is best for your needs at that point in time).
Have fun!
Zegord
Get a 2nd BR1 Pro 5G. Setup the 2nd device on the ethernet WAN port of the main device.
The flipping back and forth becomes tedious real quick as you move from place to place and then constantly trying to figure out which carrier is best in a given spot. Even still that carrier can become bogged down while your there and yet all the signal strength is solid. Signal strength is not a guarantee of performance. I also do not like paying for service on 2 carriers and only using 1 of them 90%+ of the time. I work remotely and use SpeedFusion for reliability above and beyond just having basic failover of sessions between 2 carriers.
I have 2x BR1 Pro 5G in my campervan with roof mounted Panorama mimo antennas.
would be great to see a dual modem br1 pro 5g!
