If using the ACW-411 console adapter, on the BR1 Mini if you enable ‘Serial to Network’ in the UART settings there’s an option for to enable Web Console. The help icon says you access it at http(s)://host:port/webconsole/. Does that require a plugin or something to work?
Chrome: sent an invalid response. ERR_INVALID_HTTP_RESPONSE
With Edge and IE is displays content unformatted and scrolling
What do we need to do to use the Web Console?
