I just bought a BR1 Mini and looked at the user manual online. It is quite a book. I need to set-up the device with 1 sim with Bell Mobility and the other one with Rogers. Should I leave the default set-up and just register the sim and imei with both companies or I need to make changes here and there.
Thank you Tim.
I have another question if I may. As the device will be in operation in a remote location and only powered by AGM battery and solar panel, is there a way to reduce the 12 watts power consumption S per specs.
If the device is powered off during the day and turned on at night is everything will be up and running as per last configuration? Or we will need to set it up again?
Pierre Paris,Cadd
Industrial Drafter
SmartPOLE Division
Construction Site Security•Portable Audio-Video Surveillance Device Rentals•Integrated Security Systems • Camera Systems • Video Verification • Alarm Systems • Access Control
I confirm that upon power up the device will retain the last configuration. It is stored in Non-Volatile memory and the only way to change it would be a manual change, pin reset or a change made via InControl2 and pushed out to the device.
