If you are going to operate your Pro LTEA on cellular then yes, you need antennas connected to the ports. All cellular antennas and cables sold by Peplink use the proper gender of SMA connector. Here’s some guidance that was previously provided as to the various cel antennas furnished by Peplink → Choosing the right indoor cellular antenna .
OK … the 2nd part of your question … Wi-fi antennas are different by design and also have a different SMA connector. Campground wi-fi varies a lot and is generally not all that great – although we know of a couple of real exceptions. If you can, I’d consider an antenna such as ANT-MB-22G-Q-B-1 or ANT-SLM-22G-S-B-6. And, if either would work, I’d go with the former. Both of these models integrate cellular and wi-fi.
