(1) Antenna
- The IP55 enclosure demonstrates almost complete protection from particles, making it perfect for heavy-duty use.
- The built-in MIMO directional antennas and external antennas are software selectable, allowing optimization for any usage.
- The IP67 enclosure is ideal for any industry needing protection from harsh conditions featuring integrated cellular & GPS Antenna.
(2) GPS
- The BR1 IP67 is embedded with built-in GPS fleet tracking and IC2 whereas the BR1 IP55 supports IC2 only.
(3) Dual-Band Wi-Fi
- The BR1 IP55 features both 2.4GHz and 5Ghz frequencies simultaneously which provides a faster and reliable Wi-Fi hotspot anywhere.
- BR1 IP67 supports 2.4GHz only.
(4) Ethernet port
- BR1 IP67 features 1 LAN Port whilst IP55 has 2 LAN ports and 1 WAN port.
(5) PoE output
- With an additional accessory PoE Injector (ACW-107), BR1 IP55 provides a LAN port as 802.3at PoE output, minimizing cables.
