(1) LAN Port
- The BR1 Pro is equipped with 4 LAN (GE) ports to support your wired connections.
- The BR1 Classic has 2 (FE) LAN ports.
(2) DIN Rails Mount
- The BR1 Pro can be uniquely mounted on DIN rails from different angles, fitting into the tightest of spaces.
(3) Mobile Ready
- The BR1 Pro allows flexible and secure power supply installation via the terminal block. With built-in GPS and Ignition sense, this is ideal for in-vehicle deployments.
- BR1 Classic features a GPIO power port (input & output functions) with toughness guaranteed.
